timberbeard
Jan 09, 2019Aspirant
Messed up registration (on company end)=no support
802.11ac Dual Band Gigabit 450+1300 Mbps sole user at home what is "firmware, OS, environment"?
I used to get the correct updates to firmware and sailed along seamlessly for some tim...
- Jan 10, 2019
There is support for the R6400, including a manual, somewhere at the end of this link:
>>> R6400 | Product | Support | NETGEAR <<<
You can download firmware from there.
The release notes tell you how to apply the firmware.
See also Update the Router Firmware in the manual.
michaelkenward
Jan 10, 2019Guru - Experienced User
- timberbeardJan 18, 2019Aspirant
Thanks very much Michael Kenward. Got 'er done. Sorry I was being a big baby. I can never take months off from anything technical, then when I come back, get it right on the first try.
(needed to update firmware from 1.0.23.34 to 1.0.1.46 via Mac support login rejected)
