timberbeard's avatar
timberbeard
Messed up registration (on company end)=no support
802.11ac Dual Band Gigabit     450+1300 Mbps           sole user at home  what is "firmware, OS, environment"? I used to get the correct updates to firmware and sailed along seamlessly for some tim...
  • michaelkenward's avatar
    Jan 10, 2019
    There is support for the R6400, including a manual, somewhere at the end of this link:
    >>> R6400 | Product | Support | NETGEAR <<<
    You can download firmware from there.
    The release notes tell you how to apply the firmware.
    See also Update the Router Firmware in the manual.
