Warren57
Feb 13, 2026Aspirant
Metal building wifi
Another remote metal building question. i live on an acreage. Added a wavlink extender to my network at the house. Works good everywhere across the acreage, good signal, except wifi signal inside me...
Feb 14, 2026Guru - Experienced User
No. But you could always do 2 extenders.
Put one exterior and run an ethernet cable from that interior to the other extender that you'd put inside.
Or depending on the distance and budget, do it right and get a point to point system that you'd mount on the house and another you'd mount on the metal building. Then you'd run an ethernet cable from the one on the metal building interior and put your access point/extender in there.
Warren57
Feb 15, 2026Aspirant
I have a wave link extender at the house which has a strong signal outside the metal building. But the NETGEAR extender is on the inside of the building so it can’t get the signal, if I move the NETGEAR outside or open the door there’s a strong signal.
i need a way to get the signal into the building
