Warren57
Feb 13, 2026Aspirant
Metal building wifi
Another remote metal building question. i live on an acreage. Added a wavlink extender to my network at the house. Works good everywhere across the acreage, good signal, except wifi signal inside me...
Feb 17, 2026Guru - Experienced User
Before ordering stuff, do some speed testing. Daisy chaining extenders drops speeds a lot and adds a lot of latency. (usually over 50% reduction each hop with standard single/dual band extenders). Take your extender and run an extension cord outside to use it, then test the speeds on the device connected to it. See what speeds you get and if they're usable for what you want it for. If so, great, use that option. If not, then we'd need to try something else.
Warren57
Feb 17, 2026Aspirant
Bear with me please, I have and xfinity gateway in the house. I added a wavlink wifi accesses point to it and that access point is delivering signal everywhere on the acreage. Then I put an old netgear extender I had that I used in the past. That extender is wifi and has no cable. I can take it outside the shop and it has a great signal. We were suggesting adding another wifi access point and connect it to the net gear in the shop.
So, I’m confused on what you suggest I take outside?
