Warren57
Feb 13, 2026Aspirant
Metal building wifi
Another remote metal building question. i live on an acreage. Added a wavlink extender to my network at the house. Works good everywhere across the acreage, good signal, except wifi signal inside me...
Feb 18, 2026Guru - Experienced User
An extender by its very nature cuts throughput by 50% because it uses the same chip to go router---->extender and then extender----devices. And it can't do both at once. Plus you have to factor in distance/obstruction. Because of those its usually 30-45% that most people see for speed. So you won't see that 900+ speed out of any extender setup. The router that CrimpOn posted will be your best bet and provide a solid connection. maybe not as good as a point to point system but it should be "good enough". Good enough means that streaming 4k only takes 25-50mbps. You should hit that without issue with what your plan is.
