Warren57
Feb 13, 2026Aspirant
Metal building wifi
Another remote metal building question. i live on an acreage. Added a wavlink extender to my network at the house. Works good everywhere across the acreage, good signal, except wifi signal inside me...
Feb 19, 2026Guru - Experienced User
What device did you end up getting?
And you placed it outdoors?
What speed did you get connected directly to the outdoor AP?
And then you ran an ethernet wire indoors to the Netgear AP?
Did you re-run the install on the Netgear ex6200 to place it in access point mode? (or it'll still be running as an extender)
