BSh
Jun 22, 2016Aspirant
Microsoft security started blocking my genie
A few days ago I noticed Microsoft security icon on bottom corner of my Netgear Genie icon. When I try to open genie I get a microsoft certificate notice if I want to allow Netgear to make changes. I...
- Jun 23, 2016
Shortcut does point to program so now I know stand alone. However, last night and this morning it started allowing me again. The Microsoft cert warning still comes up but now when I say yes, it allows genie to open. Hopefully it continues allowing me.
michaelkenward
Jun 22, 2016Guru - Experienced User
Which Genie is this? The standalone Windows program – if that one which version? – or the Genie bit of the browser interface?
I have Microsoft security and both Genies running happily side by side. No security alerts.
- BShJun 22, 2016Aspirant
I'll have to check the genie version but I do keep it updated with router model indicated. I imagine it is internet/browser based not a standalone Windows program. I use IE 11 with Windows 7. I never had a problem at all until about 1 week ago when this Microsoft Security appeared on it.
- michaelkenwardJun 22, 2016Guru - Experienced User
It is standalone if you launch it from the start menu. It is browser based if you go in via your browser.
I have a shortcut on my desktop that I use to access....??? so I am guessing browser based
