BSh
Jun 22, 2016Aspirant
Microsoft security started blocking my genie
A few days ago I noticed Microsoft security icon on bottom corner of my Netgear Genie icon. When I try to open genie I get a microsoft certificate notice if I want to allow Netgear to make changes. I...
- Jun 23, 2016
Shortcut does point to program so now I know stand alone. However, last night and this morning it started allowing me again. The Microsoft cert warning still comes up but now when I say yes, it allows genie to open. Hopefully it continues allowing me.
BSh
I'll have to check the genie version but I do keep it updated with router model indicated. I imagine it is internet/browser based not a standalone Windows program. I use IE 11 with Windows 7. I never had a problem at all until about 1 week ago when this Microsoft Security appeared on it.
michaelkenward
Jun 22, 2016Guru - Experienced User
It is standalone if you launch it from the start menu. It is browser based if you go in via your browser.
- BShJun 22, 2016Aspirant
I have a shortcut on my desktop that I use to access....??? so I am guessing browser based
- michaelkenwardJun 22, 2016Guru - Experienced User
BSh wrote:I have a shortcut on my desktop that I use to access....??? so I am guessing browser based
Not necessarily.Shortcuts can go anywhere. They can be weblinks (urls) or pointers to programs or even documents.
If it aims at:
"C:\Program Files (x86)\NETGEAR Genie\bin\NETGEARGenie.exe"
Then it is the standalone Windows thingy.
This is much more likely to upset antivirus software. But sometime that can gag on websites.
- BShJun 23, 2016Aspirant
