1y0fms
Nov 19, 2016Aspirant
Microwave Interference
Model WNDR3400v3 Firmware V1.0.1.4 The microwave keeps interfering. I have the channell selction at auto. Often it is on Ch 8. What can I do to eliminate microwave interference??
- Nov 19, 2016
yeah . . say, i did try chnaging to ch 1. We will see how that goes in the next day or 2. OK?? I mean if I could switch to 5 Ghz that would be great .. but I did chnage the channell. I noticed all my neighbors are normally between 6 and 8. So I will give 1 a try . .
TheEther
Nov 19, 2016Guru
1y0fms wrote:
The ROKU is 4230X ROKU 3
Would using 5 Ghz affect my Netgear extender??
Yes, if you want your extender to extend 5 GHz.
Is your Roku currently connecting through your extender?
1y0fms
- 1y0fmsNov 27, 2016Aspirant
Changing to ch 1 solved the microwave interference problem. Thank you very much!
