Zoiinkzz
Jan 03, 2020Aspirant
Minecraft Port Fowarding
So I have a D6220 router (not an option to put in for some reason) I’ve been trying to forward my ports to play minecraft (25565) with my friends for at least 2 days now, I’ve watched videos and done ...
- Jan 06, 2020
> I'm not too sure what you mean by value here
The _numbers_. The actual _numbers_. Not "like xxx.xx.xx.xx" or
"the number i get when i search for my public IP". The actual
_numbers_. I don't even need _all_ of them; the first half would be
fine:> [...] "a.b" out of "a.b.c.d" would be enough.
> [...] im sorry but it dispays like xxx.xx.xx.xx but that number does
> not match the number i get when i search for my public IPThat could be your problem:
https://en.wikipedia.org/wiki/Carrier-grade_NAT
If your ISP is using carrier-grade NAT, then your router will not get
a public WAN/Internet IP address, and so you will not be able to make
port forwarding work.
You could try asking your ISP if you can get a public address. They
might charge extra for that, if they'll do it at all. Some ISPs dislike
servers for residential customers.
Zoiinkzz
Jan 05, 2020Aspirant
I’ve checked them all, one was similar but they had a modem and router separately but I just have one, if it’s a router modem combo what am I meant to do to fix the port forwarding?
michaelkenward
Jan 06, 2020Guru - Experienced User
Zoiinkzz wrote:
...if it’s a router modem combo what am I meant to do to fix the port forwarding?
You should be able to ignore the modem bit.
Your router is the same as the standalone router when it comes to things like port forwarding.
- ZoiinkzzJan 06, 2020AspirantSo then port forwarding should be working right? But it’s not I’ve done everything right and followed tutorials to the letter but it’s still not working
- antinodeJan 06, 2020Guru
> [...] I have a D6220 router [...]
Connected to what?
ADVANCED > ADVANCED Home : Internet Port : Internet IP Address? Does
that address match your public IP address?> [...] I've watched videos and done everything the same step by step of
> the way [...]That non-description conveys no useful information to the
non-psychics in your audience. Who also can't see your port-forwarding
rule(s).> [...] I've done everything right and followed tutorials to the letter
> [...]It's nice that you're happy, but, again, no idea of which
"tutorials"; no idea of what you did.
> [...] but it's still not workingNo idea of how you determined that, either.
None of that is a useful problem description. It does not say what
you did. It does not say what happened when you did it. As usual,
showing actual actions (commands) with their actual results (error
messages, LED indicators, ...) can be more helpful than vague
descriptions or interpretations.- ZoiinkzzJan 06, 2020Aspirant
so basically from the start i find my IPv4 from cmd ipconfig, enter that into the port forwarding/trigging section press add and enter the ports i want forwarded which is (25565) click apply and that should be it but when i go to any port checking sites it will say that the 25565 port isnt open with the server running or not. I dont see any error messages or anything like that it just doesnt show up that the ports are open on sites like canyouseeme.org
One thing you said though was if my public IP matched what it said in the Advanced Home page and it doesnt, when i go to look at it the box that says "get dynamically from ISP" is checked
Sorry if its too vague but thats practically all the info i know
