Zoiinkzz
Jan 03, 2020Aspirant
Minecraft Port Fowarding
So I have a D6220 router (not an option to put in for some reason) I’ve been trying to forward my ports to play minecraft (25565) with my friends for at least 2 days now, I’ve watched videos and done ...
- Jan 06, 2020
> I'm not too sure what you mean by value here
The _numbers_. The actual _numbers_. Not "like xxx.xx.xx.xx" or
"the number i get when i search for my public IP". The actual
_numbers_. I don't even need _all_ of them; the first half would be
fine:> [...] "a.b" out of "a.b.c.d" would be enough.
> [...] im sorry but it dispays like xxx.xx.xx.xx but that number does
> not match the number i get when i search for my public IPThat could be your problem:
https://en.wikipedia.org/wiki/Carrier-grade_NAT
If your ISP is using carrier-grade NAT, then your router will not get
a public WAN/Internet IP address, and so you will not be able to make
port forwarding work.
You could try asking your ISP if you can get a public address. They
might charge extra for that, if they'll do it at all. Some ISPs dislike
servers for residential customers.
Zoiinkzz
Jan 06, 2020Aspirant
> go to the manual
I went through the steps the manual showed and in LAN Setup which is where i reserve and IP adress the one i get from cmd ipconfig was already on the reserve list
>some paremeters in a port fowarding...
So for the name i just named it "Minecraft" so i remebered what it was for, Service Type is TCP/UDP, External Starting Point: 25565, Internal STarting Point: 25565 and the internal IP address is the one I get by selecting the computer im using which is also the same as the IP I get from cmd ipconfig
ADVANCED>ADVANCED home : internet port : internet IP address
I'm not too sure what you mean by value here im sorry but it dispays like xxx.xx.xx.xx but that number does not match the number i get when i search for my public IP
>Get what from where
From here i go to the Internet Setup tab and find the section that says "Internet IP Address" and just below that is the box that is checked "Get Dynamically From ISP"
antinode
Jan 06, 2020Guru
fine:
