Reith
Mar 20, 2021Apprentice
Mobile devices keeps losing wifi connection
I currently have a Orbi router RBR50 Model. I have been rebooting the router for the last week. Because my tablets and cell phones keeps losing wifi. But any devices directly connected to a satel...
Reith
Go into NTP settings. change DST from Netgear to manual and type time.nist.gov This should resolve the wifi lose issue. Give it 12-24 hours to see if it works and repost here your status. Thank you Have a nice day
Froo
Mar 22, 2021Tutor
Unfortunately I'm still having the problem. I should clarify that my actual problem is the reverse of the one in the subject line on this thread. I lose connection to the wifi on most of my computers but seem to keep it on my phones. This is still happening three times a day: before 6AM, ~7PM, ~10PM
- ReithMar 22, 2021ApprenticeDid you go into the NTP setting and change the DST? Also have you checked and see if there is a new firmware to update?
- FrooMar 22, 2021Tutor
No firmware update and I did change the NTP.
- DanMar85Mar 22, 2021Tutor
I made the NTP change 2 days ago ...with some noticable success - only 1 reboot needed to resolve the connectivity issue. As of 2 days ago, I was running the most recent firmware.
Thanks for the reply ... here is hoping the next update eliminates the problem fully.
