sbezner
May 02, 2021Follower
Model N600 packaging does not indicate that it can only do speed of 100MBS max. Missrepresentation
I would not have purchased if I knew and now I am stuck with this junk. So far NETGEAR is not offering any assistance or a exchange with a faster speed. What kind of company is NETGEAR to be so dis...
antinode
May 02, 2021Guru
> Model N600 [...]
"N600" is a speed, not a model number. Look for "Model" on the
product label and/or the box.
> [...] packaging does not indicate [...] Missrepresentation
With my weak psychic powers, I can't see your "packaging", nor what
it might or might not "indicate". And, without an actual model number,
it's tough to follow the usual procedure to get actual product
information:
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get some. Read.
I'd expect any device labeled "N600" to be pretty old, and I would
not be amazed if its Ethernet ports were limited to 100Mb/s ("Fast
Ethernet" ("Fast" as of 1999, that is)).
> [...] So far NETGEAR is not offering any assistance or a exchange
Did you buy it (whatever it is) directly from Netgear?
> [...] What kind of company is NETGEAR to be so dishonest.
Treating that as a question ("?"), it might be the kind of company
which can't afford to correct every mistake made by every customer.
