Prats
Mar 25, 2020Tutor
Model Number: JWNR2000V2 - N300 WiFi Router. Brief Summary: I need help in limiting internet speeds
Hi Team, I am not a tech-savvy person so need your help in limiting speeds for attached devices to router. I checked my internet speed coming from my Internet Service provider. Both Download ...
- Mar 25, 2020
Prats wrote:Hi, Thank you for the sugestion. So what is the recommended internet speed for the work? it depends on what you do for work for what speed you need. If you're a graphics/video specialist, you'll need much higher bandwidth. If you've got an IT department at your work, check with them what they'd recommend for your specialty.
And regarding my query, I still want to understand how can I limit internet speed for other devices. Can you please also reply on that.---- i don't think you can limit with that device. You can set priority by device but I dont' see any bandwidth limiting.
it was manufactured in 2011 and was a very basic router when it came out. Its behind on features, security, and performance. I'm actually a bit impressed its still running after 9 years.
Mar 25, 2020Guru - Experienced User
Ouch. 4mbps speed isn't very good.
If you NEED it for work, i'd disconnect all the other device entirely while you're working. that's going to be your best bet.
Prats
Mar 25, 2020Tutor
Hi, Thank you for the sugestion. So what is the recommended internet speed for the work? And regarding my query, I still want to understand how can I limit internet speed for other devices. Can you please also reply on that.
- plemansMar 25, 2020Guru - Experienced User
- PratsMar 25, 2020Tutor
So, the moral of the story is there is no feature of limiting speed in thsi router. Thank you for the support and guidance.
Yes, it is still running very well, no disturbance till now.
