cpq19tdh's avatar
cpq19tdh
Model R6400 AC1750 Used router cannot be registered.
Hi all,  I have a used router.  I was able to do a factory reset and log into 'router login.net to reset user id and password.  The wirless network is broadcasting.  During the firmware update, ...
  • cpq19tdh's avatar
    Dec 20, 2020
    So hello again,
    I just checked my email and had a message that my router was registered to me.   A little confused, and maybe I was a little impatient.  Not sure how it happened.  But thanks to whoever helped me.
