bearcat22's avatar
bearcat22
model R6400v2 "Authentication Problem" error message model R6400v2
Thank you for taking a look.
Windows 10 PC, Netgear model R6400v2, Alcatel Raven A574BL.
Looking for practical solutions, not negative "nothing will work" or "get a new phone"  type of garbage.
To understand this Authenticaion Failed error message I am getting, , it is helpful to understand some background.
  I almost never use my NetGear wireless router.  When I got it, it appeared to me as if it drastically slowed down my internet connection.  I only bought it to try to make an Alexa device (a gift) work. When I found out that Alexa works like trash, I disconnected both devices.
Then, my cell phone began having problems.  I spent literally forty to fifty hours on chat and phone support with my provider, SafeLink (obamaphone).   Eventually,  A support tech ruined it.  He stated that I had to  take out the battery, wait up to an hour, and everthing would work again.  Instead, this wiped out all my contacts and other vital information. Now, evidently, I have to connect to the internet to get the phone reset.
So, I drag out the NetGear router, and hook it up using the instructions here:
 https://www.downloads.netgear.com/files/GDC/R6400v2/R6400v2_UM_EN.pdf
If I ever created a password for this, it would be the password I use for everything else, and that isn't getting any response.  On the back of the device it says "Password: password"
When I turn on my phone, it leads to a bunch of WiFi names.  NetGear67 is at the top. No matter what password I put in, it leads to:
Flashing back and forth between the words "Authenticating" and "Saved"
Then "Authentication Problem"
Update:  Just plugged in the garbage Echo Dot thing, and it is functioning, so I guess the router is sending/receiving.
I took the phone to FOUR different WiFi spots outside of my home, and none of them would connect.  Safelink tech support is worse than uselesss.
No RepliesBe the first to reply
