Wbhandball
Feb 07, 2022Tutor
model wn3000RPv3
After exchanging my router, one of my wifi extenders is working fine.. I didn't even had to change passwords.. However my 2nd extender will not connect to the router even though it is 2 feet away. ...
Feb 07, 2022Guru - Experienced User
Try setting it up using the installation assistant and not wps.
Wbhandball
Feb 08, 2022Tutor
Thanks, I'll try it if I can find the instructions....
- plemansFeb 08, 2022Guru - Experienced User
