Anna43
Nov 20, 2020Follower
Model WNDR3400 Weak Security issue.
I Need to configure the Router to use WPA2 (AES) or WPA3 and cant figure out how to do it.
Nov 21, 2020Guru - Experienced User
The wndr3400 won't get wpa3. its a new wireless standard and has hardware difference.
It does support wpa2. you can set that up in the wireless settings. Page 2-10 of the manual goes over them.
https://www.netgear.com/support/product/WNDR3400v1.aspx
wcalifas
Nov 24, 2020Prodigy
You need to the wireless settings where your password is listed and you can change it to wpa2.
