FlintFenton
Feb 18, 2021Aspirant
Modem 200Mbps, Router 35Mbps
Spectrum just upgraded my internet speed to 200Mbps but I can only get 36Mbps the the router. I hardwired my pc directly to the modem and got 220Mpbs. Any suggestions on how to get more speed thru ...
Feb 18, 2021Guru - Experienced User
What router do you have?
what firmware is on it?
What modem is it connected to?
Did you try a factory reset and install on the router? (don't reinstall using a backup configuration)
