kkester
Nov 03, 2021Tutor
Modem Netgear CM700 Ethernet cable light blinking orange. But I have wifi connection.
Is this normal? This is first time I’ve had connection the last week, all of the other lights are green, but Ethernet cable light is orange, is this an issue? Or is this normal?
Nov 03, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the Cable Modem products. Most of the people who watch that forum are more likely to have experience with Cable modems and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Cable-Modems-Routers/bd-p/home-cable-modems-routers
Be sure to include the brand and model# of the external router connected to the modem as well.
Review the user manual to see what the LED behaviors are for this model modem.
Thank you.
