dippieffe
Aug 07, 2018Aspirant
Modem or not modem this is the question
Hi there on the coming Friday I got a technician from Xfinity to install my internet and I bought this router. My question is do I need a modem also or this is just enough to access the web?
I ...
- Aug 11, 2018
Thank you everyone for the time dedicated to this silly question, I returned the Netgear router and bought an Arris cable modem and router.
Thanks again and have a good summer.
antinode
Aug 07, 2018Guru
> [...] Xfinity [...]
> [...] I bought this router.
> Model: R6120|AC1200 Dual Band WiFi Router
Your "this router" is an R6120?
> [...] do I need a modem also or this is just enough to access the web?
What you need depends on what you're getting from Comcast. If that
is standard cable-TV Internet service, then you probably need a cable-TV
modem. This could be a simple cable modem for use with a separate
router like an R6120, or you could get a modem+router ("gateway") to do
the whole job, removing the need for a separate router like an R6120.
Is Comcast supplying any equipment (like, say, a modem or
modem+router)?
