dippieffe
Aug 07, 2018Aspirant
Modem or not modem this is the question
Hi there on the coming Friday I got a technician from Xfinity to install my internet and I bought this router. My question is do I need a modem also or this is just enough to access the web?
I ...
- Aug 11, 2018
Thank you everyone for the time dedicated to this silly question, I returned the Netgear router and bought an Arris cable modem and router.
Thanks again and have a good summer.
michaelkenward
Aug 08, 2018Guru - Experienced User
When it takes a technician to install your Internet, that often entails delivering a modem, or whatever box you need to let on to the internet.
Whether you need, or can use, another router with that modem depends on the box they install.
Have you asked them what they supply? The answer will help you to decide if you need anything else.
The questions to put to them include the type of internet (DSL, cable or something else) and the type of box they deliver. Is it a simple modem? Or is it a modem-router? Will it provide wifi? (If you want that.)
- dippieffeAug 08, 2018AspirantThanks guys for your input, my bad I should have given more info.
What I get from Comcast is only Internet without any device. I think the ac1200 is not the device I need, isn't it?- antinodeAug 08, 2018Guru
> [...] I think the ac1200 is not the device I need, isn't it?
An R6120 is a router, not a modem+router, so, by itself, it's not all
you need.
> [...] you probably need a cable-TV
> modem. This could be a simple cable modem for use with a separate
> router like an R6120, or you could get a modem+router ("gateway") to do
> the whole job, removing the need for a separate router like an R6120.
Still true. - michaelkenwardAug 09, 2018Guru - Experienced User
dippieffe wrote:
What I get from Comcast is only Internet without any device. I think the ac1200 is not the device I need, isn't it?Looking at the Xfinity site, they seem to be one of those naughty ISPs that likes to rent customers a "gateway" for $11 a month.
Netgear sells cable modems such as the C3000 that claim to be "Certified to work with cable Internet providers XFINITY® from Comcast, Spectrum®, Cox® & more". That is just one of many cable modems with varying extra features.
Cable Modem Routers & Cable Modems | NETGEAR
See if Comcast has a list of compatible modems.
By the way, if the wifi features were what made you think of the R6120 – AC1200 is a wifi speed designator, R6120 is the model number – the C6220 is the cable modem with the same claims for its wifi.
- antinodeAug 09, 2018Guru
> Netgear sells cable modems such as the C3000 [...]
> [...] the C6220 is the cable modem [...]
A Netgear model number "Cnnnn" denotes a cable modem+router (gateway)
unit, not a "cable modem". A Netgear model number "CMnnn" denotes a
cable modem (only) unit.
