dippieffe
Aug 08, 2018Aspirant
Modem or not modem this is the question
Hi there on the coming Friday I got a technician from Xfinity to install my internet and I bought this router. My question is do I need a modem also or this is just enough to access the web?
I ...
- Aug 12, 2018
Thank you everyone for the time dedicated to this silly question, I returned the Netgear router and bought an Arris cable modem and router.
Thanks again and have a good summer.
michaelkenward
Aug 09, 2018Guru - Experienced User
dippieffe wrote:
What I get from Comcast is only Internet without any device. I think the ac1200 is not the device I need, isn't it?
Looking at the Xfinity site, they seem to be one of those naughty ISPs that likes to rent customers a "gateway" for $11 a month.
Netgear sells cable modems such as the C3000 that claim to be "Certified to work with cable Internet providers XFINITY® from Comcast, Spectrum®, Cox® & more". That is just one of many cable modems with varying extra features.
Cable Modem Routers & Cable Modems | NETGEAR
See if Comcast has a list of compatible modems.
By the way, if the wifi features were what made you think of the R6120 – AC1200 is a wifi speed designator, R6120 is the model number – the C6220 is the cable modem with the same claims for its wifi.
antinode
Aug 09, 2018Guru
> Netgear sells cable modems such as the C3000 [...]
> [...] the C6220 is the cable modem [...]
A Netgear model number "Cnnnn" denotes a cable modem+router (gateway)
unit, not a "cable modem". A Netgear model number "CMnnn" denotes a
cable modem (only) unit.
- dippieffeAug 12, 2018Aspirant
