aaguilar22's avatar
aaguilar22
Follower
Feb 19, 2021
Modern equipment comparable to my old WNDR3700
I am in the market for a new router/modem for my cable service.  I used to have a netgear WNDR3700 I LOVED IT.  it had great range for my 2 story house.
What is the modern day equivalent?
Any help will be appreciated.
Thank you,
aa
1 Reply
  • plemans's avatar
    Are you looking for a modem and a seperate router or a combo device?
    you'll usually see people recommending buying them seperate on here.
    There's many factors for what you want in a router.
    What size is the 2 story home?
    What are the interior walls made of?
    Are you looking for a AX system or AC system?
    How fast of internet speeds do you have?
    How many devices are you using and what are you using them for (streaming/gaming/etc)?
    Are you looking for a mesh system or a single router solution?
    And even budget impacts it. Its pointless for us to recommend a $300 router if your budget is $100
