Gianca19
Jan 24, 2016Aspirant
MORE SPECIFICATIONS ABOUT NETGEAR LG6100D
Respectable Community , I am Gaetani Giancarlo and I live in Italy and I want to ask some questions: To navigate in internet I am using an internet key of italian telephone provider Vodafone.Un...
- Jan 24, 2016
I'm not an expert with Netgear's mobile broadband products, so you are welcome to ignore me. :smileyhappy:
I looked at the documentation for the LG6100D and it looks like it's specifically designed to be used with Sprint's cellular network, so you probably cannot use its built-in LTE modem. It also does not appear to accept a USB modem, so your Internet key will not work.
From what I can tell, Netgear has 4 classes of mobile broadband products:
- USB Modem
These are probably the same as your Internet key. I think they are not available in Italy. - Mobile Hotspot
These are cellular modems with Wi-Fi. Netgear calls them Aircards. There is an optional cradle (like the DC112A) that can accept an Aircard and provide expanded capabilities (extra antennas, Ethernet and USB ports). - LTE gateway
These are cellular modems with Wi-Fi, Ethernet and USB ports. The LG6100D is a LTE gateway designed for Sprint. I found the Netgear MBR1517, which appears to be designed for the European market, so it may work with one of your sim cards. - USB modem compatible router
This is a Wi-Fi router that can accept a USB modem. It looks like it's available in Italy as the MBRN3000. Your Internet key may work with this, but you should confirm that it is supported before you purchase. Unfortunately, I'm pretty sure that this will not amplify your cellular signal.
- USB Modem
TheEther
Jan 24, 2016Guru
- USB Modem
Gianca19
Gentle TheEther , I want to thank you because, reading your answer, I probably have found the solution to my problem.
Thanks again, I salute you.
