pperciav's avatar
pperciav
Moving a ReadyShare Drive from the Router
All,  I want to move my ReadyShare hard Drive from my NetGear router and connect it to my USB hub on my Laptop to access the stored files from the HD directly on my Laptop.  Is there an easy and eff...
  • DexterJB's avatar
    Feb 15, 2017
    Hi pperciav,
    If there is no need for your other devices in the network to access the hard drive via the router/ReadySHARE then you can just connect it straight to the laptop. It should not be an issue.
    Dexter
    Community Team
