Chris_1000_Oaks's avatar
Apr 30, 2021
moving from a house with fiber to the premises and need to connect my Orbi RBR50
I am moving house and at present I have Fiber to the premises and connect my Orbi RBR50 to an Openreach modem. In my new house. I am told that when the line is reconnected I should have a master sock...
  • antinode's avatar
    antinode
    May 04, 2021
    > [...] Plusnet Hub1 router modem [...]
       At last, something like a model number.
    > [...] the DSL port.
       With a DSL connection.  Whew.
    > [...] I really need the Mesh network my Orbi provides for greater
    > coverage.
       I got that.  Which takes us back to my first response.
       My quick Web search didn't find much on the Plusnet Hub1, so it's not
    obvious to me whether it has a modem-only ("bridge") mode.  If not, or
    if you can't find it, then, as previousy suggested, "configure the RBR50
    as a wireless access point".
    > When I try to search for a modem I get lots of router modems, [...]
       With my weak psychic powers, I have no idea for what you might have
    searched, or what you might have found.
    > [...] so was hoping to find the best modem [...]
    > [...] I'd avoid any Netgear DSL modem products.
       Still true.
    > [...] that supports supports dual-band Wi-Fi fast enough not to limit
    > the Orbi
       I don't know what speed your ISP promises, but I would expect a DSL
    connection using any modem to be the bottleneck in your network.
