brendanfsmith
Mar 18, 2017Aspirant
MS Nokia Lumina 928 can not connect to 2.4 GHz
I recently purchased R6400 AC1750 and setup with default settings. Cable provider is cablevision optimum online. I have upgraded to firmware V1.0.1.20_1.0.16 We have multiple smart phones (iPh...
- Mar 30, 2017
Hi brendanfsmith,
1. Please try connecting the Nokia phone to another 2.4GHz wireless network (coffee shop, office, etc.).
2. The option to change the time is under Advanced > Security > Schedule.
Dexter
Community Team
brendanfsmith
Mar 23, 2017Aspirant
Dexter
thank you
Will give that a try this weekend
DexterJB
Mar 23, 2017NETGEAR Moderator
- brendanfsmithMar 25, 2017Aspirant
no luck
I tried factory reset on the router (twice) including rebooting the modem.
the lumina will not connect to the 2.4. it very quickly (within 2 secs) returns the "your phone cannot connect to the network".
some observations that may or may not be relevant
- while monitoring the Lumina list of available networks, the 2.4G network occasionally drops from the list for 5-10 secs, then comes back for 30-60 secs. repeats. 5G seems to always be available
- the netgear router logs do not show a failed login attempt (normal?)
- the netgear router clock shows 4 hours behind. i am on eastern DST time. no idea how to change the clock/timezone (probably irrelevant, but annoying)
- i see some DoS logs [DoS attack: ACK Scan] (1) attack packets , and [DoS attack: Smurf] (1) attack packets
any suggestions would be greatly appreciated.
thanks
- DexterJBMar 30, 2017NETGEAR Moderator
Hi brendanfsmith,
Dexter
Community Team
- DexterJBApr 03, 2017NETGEAR Moderator
Hi brendanfsmith,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
