never20ld
Nov 13, 2020Initiate
Multiple networks in my home
I have 2 isps in my home. Can I set up both networks in one WN2500RPv2 extender or do I need a second extender? Larry
never20ld
Nov 14, 2020Initiate
I have two networks. One AT&T with a Pace gateway with only2.4 gHz wifi and a dual band Cisco gateway for Xfinity (Comcast). AT&T is fairly reliable(?) but slow and Xfinity is quite fast but the connection drops out during peak usage times.
I also see from another answer that only one network at a time is supported...
Thanks,
Larry
Nov 14, 2020Guru - Experienced User
The xfinity should be a fairly solid connection even during peak times. They overprovision for this.
Maybe we can get your cable connection functioning better so you can rely on 1 setup and save some $.
What modem do you have?
What router do you connect to it?
Firmware on that router?
What speeds do you pay for?
What speeds do you actually get hardwired into the modem?
How big is your home? and stories?
What are the interior walls made of? (certain materials block wifi very well)
Live in a more congested area like apartment, condo, townhomes?
Something else to keep in mind is that 2.4ghz is much more sensitive to interference. During peak times, I'd have devices on 5ghz. When I used to live in an aparment, I made sure all my devices were on 5ghz because 2.4ghz has so much issues with congestions.
