never20ld
Nov 13, 2020Initiate
Multiple networks in my home
I have 2 isps in my home. Can I set up both networks in one WN2500RPv2 extender or do I need a second extender? Larry
never20ld
Nov 14, 2020Initiate
I have two networks. One AT&T with a Pace gateway with only2.4 gHz wifi and a dual band Cisco gateway for Xfinity (Comcast). AT&T is fairly reliable(?) but slow and Xfinity is quite fast but the connection drops out during peak usage times.
I also see from another answer that only one network at a time is supported...
Thanks,
Larry
michaelkenward
Nov 15, 2020Guru - Experienced User
You can't join two internet services with bog standard consumer grade network devices. Different address on the WAN.
