littlebear
Aug 05, 2015Tutor
Multiple wifi routers one network
my home broadband is accessed via a phone line. on one access point upstairs I have installed a D3600 but the signal is too weak to access downstairs and an extender is not helping. is it possib...
- Aug 07, 2015
So you are willing to have one extra subsription to your ISP? Then do it and see how it goes coverage wise.
Babylon5
Aug 06, 2015NETGEAR Employee Retired
Littlebear, your post appears a little confused. Your D3600 is a DSL modem/router and it’s the modem function of the D3600 that enables it to connect to your phone line and onwards to your ISP. I’m not DSL expert, but I don’t think you can simply add a second DSL modem/router to another phone connection point in the house. What you can do, which is what I think Daenerys is suggesting, is to connect the other router to the D3600 via Ethernet cable, and configure the second router as an Access Point. Just out of interest though, do you already have that second Nighthawk router that you refer to?
littlebear
Aug 06, 2015Tutor
Hi Andy,
thanks for your response.
yes I do already have the Nighthawk. I'm currently attempting to set it up first as the primary router with the D3600 disconnected, before seeing if both will connect.
Having trouble getting it to recognise the ISP log-in, working in that at the moment
- Babylon5Aug 07, 2015NETGEAR Employee Retired
What is the model type of the other Nighthawk? If it’s a Dxxxx then it can connect to your phoneline, if it’s an Rxxxx then it does not contain the necessary DSL modem to be able to connect to the phoneline. Whatever the case, I suggest that you really only want to create one network where you have one primary router/gateway connected to the phoneline, and maybe a secondary router configured as an access point (since you already have a second router).
- VE6CGXAug 07, 2015Master
Hi, OP,
Please draw a block diagram of your network keeping in mind what you want to do.
And already mentioned Dxxx and Rxxx is two differet beast. Think one router(R7000)
bridging the Dxxx, then think AP. If you don't want to run Cat 5 or Cat 6 cable where
needed, then consider power line adapter...
- littlebearAug 07, 2015Tutor
Sorry working on iPad can't attach a drawing
basically the house is U shaped and two levels.
On either end of the U is a phone line into the house.
One is attached to D3600
I'd like to attach the second modem router Nighthawk AC1900 to the other phone line?
think power line adapter might be the best solution,
