sotackd
Oct 14, 2021Aspirant
Mutliple Failed Logins on router
I have C3700v2 (not listed above) and logs indicate that the Ethernet connected PC has several failed logins to the router. I have reset the Admin password to a hardened password. I have checked the...
michaelkenward
Oct 15, 2021Guru - Experienced User
Is it just the logs that show this behaviour? Does something on the network lose a connection?
Have you tracked down whatever device has that IP address? Does it show any symptoms?
While many issues are common to most routers, in this case the C3700v2 is a cable modem/router, which may make a difference.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Cable Modems & Routers
sotackd
Oct 15, 2021Aspirant
It's a Windows 10 PC attached to the router via ethernet. I have found no issues on the attached PC it is up to date as far as Windows patches and Avast Virus updates. A full virus scan is clean. My brother in law uses the PC daily and has no issues. All other devices connect wirelessly and seem to be fine. I was thinking Avast does this as part of a vulnerability scan but have not found anything on the web to indicate this.
