camomiletea's avatar
Dec 06, 2015
My 5g network doesn't show up
I have the N600 Wireless Dual Band router(WNDR3400v3), and I think the 5g used to show up... at least for a little bit, but not anymore. I've tried changing settings - disabling and reenabling them (...
  • TheEther's avatar
    TheEther
    Dec 06, 2015
    Yeah, that's a single band adapter.  There's no way the 5G network would have appeared on it.  You must have imagined it.  Or, perhaps, you gave your 5G network the same name as an old 2.4G network?
