Denbers
May 03, 2020Tutor
My AC1200 EX6110 when I try to connect to it says i am entering the incorrect password. It does conn
- May 04, 2020
to reset you have to push and hold the reset button for 7-15 seconds. it shouldn't auto-reconnect if it was fully reset
May 04, 2020Guru - Experienced User
What router are you connecting to?
Try factory resetting the extender and re-running install using the installation wizard and not wps.
Denbers
May 04, 2020Tutor
Hi , thanks for the info, I'll try that tonight. I pressed the reset button last night but it reconnected via WPS straight away.
