Bradwg93
Aug 04, 2021Follower
My AC1600 will not connect and every icon is blinking
Does anyone know what to do when everything is blinking? The power went out and now every icon is blinking and I can’t figure it out and get back on WIFI.
Aug 05, 2021Guru - Experienced User
When everything is blinking, it tends to not be a good sign with modem/router combo devices.
What I'd try would be to disconnect everything from the modem including the coax. Then while powered on, push and hold reset for 7-15 seconds. Hopefully it boots back up.If it does, reconnect the coax to it and attempt to set it up.
If it doesn't, your only other option would be to contact the isp to see if they're able to ping/see the modem on their network. If they can, potentially then can re-provision it. If not, you might be SOL
