needhelp975
Apr 29, 2024Aspirant
My Internet LED is solid amber but i have no MODEM
My Internet LED is orange/amber i have tried resetting it and looked at tutorials online, yet nothing worked and it says I have to have a modem, I only have a tv and a box I use to watch tv
Internet Service Provider.
Your model router is getting old. Maybe time to get something new.
What NG model product are you referring too?
Ask the ISP to reset or reboot there equipment.
- needhelp975Aspirantmy model is the WNR2200, i don’t know what ISP is
to watch tvThe WNR2200 is a router that dates back to 2010. On its own it can't connect to the Internet. It needs something else, usually a modem. Maybe that is the box you use to watch tv. (What is it?) There is certainly something between your WNR2200 and the outside world.
Before you rush off to replace this ancient device – not the most helpful advice without more details to guide your choice – you need to work out how the Internet gets to you. Then pick something that works with the Internet service provider you use to deliver your Internet connection.
If the WNR2200 still works and does what you need, why spend more money? For a start anything wired to it is limited to 100 Mbps. That's slower than many Internet services. Then there is the wifi. It is stuck on 2.4 GHz, which is slower than most mobile phones and other things can use.
