Juls9503
Nov 26, 2021Aspirant
My modem is a AC1750 C6300. Cant access The Modem/Routers Settings
I am trying to access the settings in my Modem/Router but for some reason when i try to use the IP Or the website it shows on the modem it says this site cant be reached please help
- Juls9503Aspirant
I've already tried resetting the modem/router and all that. I've been having this problem for a pretty long time but didnt really mind it back then because i haven't had to use it but now i need it.
This isn't clear.
What do you mean by "when i try to use the IP Or the website it shows on the modem"
Use the IP in what? And what "shows the modem"?
What are you doing and where does it go wrong?
And what says "this site cant be reached"?
Browser? An app? Something else?
These might be useful.
How do I log in to my NETGEAR wireless router? | Answer | NETGEAR Support
and this:
If you cannot login to your router | Answer | NETGEAR Support
Your subject says C6300. Is that what you have?
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Cable Modems & Routers
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
