Pjvan's avatar
Pjvan
My netgear N300 has stopped working, I purchased a new identical one, can I just swith them with res
My router stopped working, I bought another one( same model) can I just switch them out without changing all my settings?
  • plemans's avatar
    May 13, 2019
    There have been 5 different version of the wnr2000. You don't list which n300 router you have, your signature has r2000 which isn't a router but there is the wnr2000, so I'm assuming you have that model. Again assuming. (could be poor choice)
    If its a different version, then don't re-use your configuration file. Just redo your setup and backup the configuration. Backups don't work between different models and it isn't recommended between different versions. michaelkenward was correct if its exactly identical model and version.
