Eggplant
Jan 08, 2021Aspirant
My Netgear password changed backed to default password.
Nighthawk AC1900 wfifi cable modem router: it seems the the custom password I had has been changed back to default. I come home after a 3 day business trip; and can't figure out why None of my devices were connecting. After several attempts I try the default. It works. I try to login into the nighthawk app. User name : admin. Password is password...it keeps saying incorrect. Have I been hacked? Should I replace?
Doubt you've been hacked. Probably just your isp updating firmware or sending a reset since they control the firmware/reset actions being a combo device.
I'd just factory reset and do a clean install on the modem/router combo device (not from backup).
(BTW, AC1900 is a speed, not a model)
- EggplantAspirant
Thanks for the qick response and solution. C7000v2 (4TU1847EA2009
