cjerfan007's avatar
cjerfan007
My netgear R6120 not showing option of remote management in Nighthawk APP
My netgear R6120 not showing option of remote management in Nighthawk APP. I can’t access my router outside via Nighthawk APP.
  • Remote management has been removed some firmware versions ago mostly due to security concerns.
    • cjerfan007's avatar
      cjerfan007
      Is it also removed form Nighthawk App? Would I not able to access my router outside LAN via Nighthawk App?
      • michaelkenward's avatar
        michaelkenward
        Guru
        Yes if you set it up.
        Remote Management is now Anywhere Access in the Nighthawk and Orbi apps | Answer | NETGEAR Support
        By the way, don't expect much from your router. According to Netgear's manual for this device, not always the most reliable source of information, the LAN and WAN ports support only 10BASE-T or 100BASE-TX. That makes it slower than many newer internet services and most modern network hardware. This may not matter to you, but be warned that it will hobble you if you ever sign up for faster Internet, anything faster than 100 Mbps is a waste of your money.
        It also slows down whatever is going on in your local network. Newer devices support at least 1000BASE-TX.
