SarwarFX
Oct 31, 2022Aspirant
My Netgear router WNR2000v5 does not provide internet for Android TV
Model: WNR2000v5 It works fine with everything except an Android TV box. Any solution?
michaelkenward
Nov 01, 2022Guru - Experienced User
SarwarFX wrote:
Model: WNR2000v5
Your WNR2000v5 is clearly working as intended. The problem is with your Android TV box.
What is that TV box?
What messages do you see?
Have you sought help from the people who support it?
There isn't much that you can do on a router that works as intended.
- SarwarFXNov 01, 2022AspirantThe android box is also working fine with other routers except this one. The TV box and router are just not compatible I think
- michaelkenwardNov 01, 2022Guru - Experienced User
SarwarFX wrote:
The android box is also working fine with other routers except this one.You can't just move a device from one router to another. Settings that work on one router may not apply to another one.
As wcalifas says, did you restart everything?
And what about the modem/gateway/ONT between the router and the Internet?
SarwarFX wrote:
The TV box and router are just not compatible I thinkThe router isn't likely to be the issue. They are all pretty much the same.
As to the TV box, ask the people who made it.
