SarwarFX
Oct 31, 2022Aspirant
My Netgear router WNR2000v5 does not provide internet for Android TV
Model: WNR2000v5 It works fine with everything except an Android TV box. Any solution?
SarwarFX
Nov 01, 2022Aspirant
The android box is also working fine with other routers except this one. The TV box and router are just not compatible I think
michaelkenward
Nov 01, 2022Guru - Experienced User
You can't just move a device from one router to another. Settings that work on one router may not apply to another one.
As wcalifas says, did you restart everything?
And what about the modem/gateway/ONT between the router and the Internet?
The router isn't likely to be the issue. They are all pretty much the same.
As to the TV box, ask the people who made it.
