SarwarFX
Oct 31, 2022Aspirant
My Netgear router WNR2000v5 does not provide internet for Android TV
Model: WNR2000v5 It works fine with everything except an Android TV box. Any solution?
SarwarFX
Nov 01, 2022Aspirant
I think this is the most appropriate point. I'm thinking about changing the router.
michaelkenward
Nov 01, 2022Guru - Experienced User
Probably a good idea. That model is from 2014. The first (V1) version is even older.
No Gigabit Ethernet. No 5 GHz wifi.
And never the most capable box in the block.
More trouble than it is worth.
- SarwarFXNov 01, 2022AspirantThanks to everyone for responding to my discussion. I have been experiencing the issue for one year.
- michaelkenwardNov 01, 2022Guru - Experienced User
It did well to keep you going that long.
- SarwarFXNov 01, 2022AspirantI bought it in 2019. It was all good until I started using an Android TV box. I still like it. I wouldn't let it go but looks like I just have to. By the way it was my first Netgear product. I was introduced with Netgear by this product.
