Katielou56
Sep 30, 2023Follower
My new printer wants my Encryption key - where do I find that?
rayj193
Oct 01, 2023Aspirant
The encryption key for your printer is typically your Wi-Fi password or network security key, used to connect the printer to your Wi-Fi network. You can usually find this key on a label located on your Wi-Fi router, often labeled as "WPA Key," "WEP Key," or "Wi-Fi Password." If it's not there, you can access your router's admin page through a web browser, where you'll find the password in the wireless settings section. Alternatively, you can contact your Internet Service Provider (ISP) for assistance or check device documentation if you've previously connected a device to the network. If all else fails, you may need to reset your router to its default settings, but this should be a last resort as it will reset your network name and password to defaults, requiring reconfiguration of all connected devices.
michaelkenward
Oct 01, 2023Guru - Experienced User
Boilerplate linkspam.
Best ignored.
Reported.
