paulEas's avatar
paulEas
Follower
Nov 05, 2020
My new switch Not connecting as expected
I have a Nighthawk x6 r8000 router, when i connect my GS108v4 it does not appear in the attached Wired Devices List, only the 2 desktops are listed. Because of this nothing connected to the switch is being seen.
1 Reply
  • plemans's avatar
    The GS108v4 is an unmanaged switch. It won't show up in your attached devices page.
    You put "only the 2 desktops are listed". Are they connected through the switch?
    the GS108v4 has led's on each port. for the devices you connect to it, do they light up?
    https://www.netgear.com/support/product/GS108v4.aspx
