marissakosten's avatar
Nov 04, 2016
MY NONWORKING ROUTER
MY ROUTER MYSTERIOUSLY STOPPED WORKING AND NOW THEY TELL ME I NEED TO BY SUPPORT FOR THEM TO SOLVE THE PROBLEM.  MAKES NO SENSE, I BOUGHT A PRODUCT AND IT SHOULD WORK REGARDLESS OF THEIR SUPPORT. ANY...
  • Retired_Member's avatar
    Retired_Member
    Nov 04, 2016
    IF YOU REGISTERED IT GO TO MYNETGEAR.COM AND CHOOSE REPLACE MY DEFECTIVE DEVICE.
