Innocentpro
Nov 24, 2020Tutor
My pc is not connecting to my extender's existing network
Hi, I have a problem with my pc's connection to my wifi extender. The extender is working perfectly fine with all devices including the pc i am talking about but thats not the problem. I want to open...
- Nov 24, 2020
Look up the ip address for the extender in the routers attached devices page (or equivelent). Use that to access it.
the mywifiext . net requires the router to direct the connection to the extender. Some ISP or other manufacturers devices don't do it properly.
Nov 24, 2020Guru - Experienced User
- InnocentproNov 24, 2020Tutor
It worked, thanks.
