Elliesne
Jan 08, 2024Aspirant
My phone can’t connect to the R6020-router
Hi! I bought my router back in 2019 and used it for about two months and haven’t used it since. Now I wanna use in my new apartment but can’t get it to connect to my phone despite all the symbols being green. I’ve restarted the router several times and I still can’t get it to connect to my phone. I have an iPhone xs and I’ve tried to enable local network access but the app can’t be seen in the WiFi-privacy settings, so I can’t manually enable it. It’s been driving me crazy and I don’t know what else to do, can someone please help me??
Elliesne wrote:
I’ve restarted the router several times and I still can’t get it to connect to my phone.Your router does not connect to the phone. It is the other way round. You have got it right in your subject.
The router broadcasts a wifi signal and your phone connects to that.
If you are using an iPhone, this might be useful:
NETGEAR Mobile Applications and Apple Devices FAQ - NETGEAR Communities
I have an iPhone xs and I’ve tried to enable local network access but the app can’t be seen in the WiFi-privacy settings, so I can’t manually enable it.Are you trying to use the Nighthawk App to set up your router? It can be a lot easier of you do that with a web browser and the graphical user interface (GUI) and a wired connection from a PC to the router.
- ElliesneAspirantThanks for the info! I’ve tried to find the feature where I can enable it manually according to the manual you linked but my phone can’t find the router and the wifiname isn’t in the list of wifis so I can’t manually enable the private IP-address. And I don’t have the ability to do it through my computer so I have to do it through the app. Do you think it matters I’ve set it up once before or is my phone the only issue?
Just an FYI, the R6020 isn't gigabit-capable. Its on fast ethernet so 10/100mbps capable. If your apartment has faster speeds, it'll bottleneck you. Its a super basic router and family ancient.
