Avanozzie
Dec 30, 2020Follower
My phone says I am using WPA/WPA2 (TKIP) but the router setup says I'm on WPA2 (AES)
I was having issues with my Wi-Fi today so I reset my router. Now my phone says that my network has "Weak Security" and that I am using WPA/WPA2 (TKIP). I tried to log into my router on my Mac, but...
antinode
Dec 30, 2020Guru
> [...] the pages for both http://routerlogin.net and
> http://routerlogin.com do not load for me. [...]
> [...] typing in the IP and that also did not work. [...]
What _does_ happen?
"do not" or "did not" is not a useful problem description. It does
not say what you did. It does not say what happened when you did it.
As usual, showing actual actions (commands) with their actual results
(error messages, LED indicators, ...) can be more helpful than vague
descriptions or interpretations.
> [...] When I went to the settings it says that I am using WPA2 (AES).
_Which_ "the settings"? A C6300 is a dual-band router with multiple
SSIDs (including the "Guest Network" SSIDs). Each SSID can have its own
"Security Options". Are yours all the same?
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual. Read. Look for "Specify Basic
WiFi Settings" and "Change the WiFi Security Option"?
