Joel46
Sep 28, 2022Aspirant
My R6080 seems to be throtteling youtube ever since i updated it.
As the title says. My router have been working fine until around 2 weeks ago when i updated my router with the latest firmware. I have this across all my platforms (2 phones and a stationary computer...
- Sep 28, 2022
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?Try a wired connection vs wireless connection...
michaelkenward
Sep 29, 2022Guru - Experienced User
A factory reset isn't going to do much, if anything, for your router.
The R6080 is one of those strange Netgear routers with slow ethernet ports.(They actually label them "Fast", which was fine back in the 20th Century.)
According to Netgear's manual for this device, not always the most reliable source of information, the LAN and WAN ports support only 10BASE-T or 100BASE-TX. That makes it slower than many newer internet services and most modern network hardware. This may not matter to you, but be warned that it will hobble you if you ever sign up for faster Internet, anything faster than 100 Mbps is a waste of your money.
It also slows down whatever is going on in your local network. Newer devices support at least 1000BASE-TX.
The speed you see, 90 Mbps, is probably the limit as far as 100BASE-TX goes.
How fast us your Internet connection?
If your ISP is delivering >100 Mbps. you are wasting money.
Joel46
Sep 29, 2022Aspirant
Hi!
Thanks for the information. The factory reset seems to have worked, hopefully the issue is solved for good:)
I only have 100/100 (i am not sure of the up speed), but will bear this in mind if i ever upgrade.
Thank you both for your time and I wish you a good weekend!
- FURRYe38Sep 29, 2022Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
